Anyone ever redo one this bad?
Farmall MD
07-22-2007 15:40:24
third party image
Been toying with the idea of redoing this one. It's been sitting for about 35 years. EVERYTHING is fast on it. I can just imagine what the inside of the case and gears look like. Anyone restore one this bad before?
I'd like to do it because it was my grandfather's A. It's a 1936. It was also the first tractor the dealer sold when they opened up. It kind of has some sentimental value and the fact that it was the first tractor the dealer sold is interesting too.
I know this will not be done overnight. It'll take a few years. But if I'm able to use the the main trans and diff, in my mind it would still be his tractor. I'd like to use everything I can from it. But I won't know how bad it is till I tear into it. Any sugestions? Doug N
TIMAR
07-23-2007 19:50:40
 Re: Anyone ever redo one this bad? in reply to Farmall MD, 07-22-2007 15:40:24
I have started with a lot worse (and less). That one looks to be complete yet. Once you tear into them, you will find they were built fairly simple. And, if you have ?'s , everyone on this board is really helpful. GOOD LUCK.
Mike Seabaugh
07-23-2007 06:18:46
Any tractor that is a fathers or grandfathers should be preserved. We restore tractors full time and the majority are a relatives. I have three unstyled JD's myself. 2 1936 A's and 1 1936 D. They all run good.I consider them a part of agriculture history. I will never scrap out a tractor that is mostly all there.
larry baker
07-23-2007 05:36:04
love unstyled tractors
my grandpas tractor ended up as canned meat in the war so i would forsure keep this story for the generations to follow with the farm sales and everything going the way of the buffalo
Mike M
07-23-2007 05:28:38
Looks pretty good to me ? You can buy new hoods and radiator cores. Used parts should be around for those as are NEW ones from JD. The thing that you may ? find out is the real reason it was left sitting. You may have to tear into it deep to find out. Alot of times it was because someone left the block or head freeze and break or sometimes the tranny got some breakage. I have not yet found one that was left set in good shape otherwise they would still be running it.
With your family connection to it for sure get started on it and see what's wrong and if you can pick up a donor tractor that's the way to go.
HAPPY DEERE
07-23-2007 04:52:09
just find you a nice parts tractor
Farmall MD
07-23-2007 01:24:57
Thanks for all the replies. Sentimental value is worth more than anything, the way I look at it. Yeah, it will be worth it. Oh, and Tim Wafer, My handle is Farmall MD, I love red too. Nice job on the F-14. Thanks, Doug N
TimWafer
07-23-2007 08:20:02
 Re: Anyone ever redo one this bad? in reply to Farmall MD, 07-23-2007 01:24:57
Didn�t even notice that Doug! I don�t generally look at the JD board that often. I do have a number of JD implements but no tractors except for a 111 lawn tractor. I did attend the recent 2-cylinder expo in Canandaigua NY this month however. Like them all but still I seem to prefer the red ones. Good luck with your project. PS: I�ve always wanted an MD!
Tim
island a
07-22-2007 18:24:53
i would be willing to bet that tractor is not in as bad a shape as you think... excepting the sheet metal. all the castings will probably be salvageable after rust removal, and the inside of the main case is prolly ok due to being filled with oil...
i have a 1939 A in that condition that i will be redoing...
GO FOR IT
Ben.So.Tex
07-22-2007 17:06:53
Of all the tractors that I have, I only bought one running tractor home, (and the wife has told me that I lost my mind when I bring one home) All the rest were DEAD/STUCK and more, Good Luck.. I have a 1936 A and enjoy it.
Take some picture as you go to work on it.
Later Ben
Rob Hartman
07-22-2007 17:00:29
This is just my opinion, every unstyled John Deere is worth rebuilding. There are too many that have already been parted out. There is probably nothing wrong with the rear end at all maybe just a little water from condensation. Nothing a little diesel can't clean up. As far as the engine, if it was full of antifreeze may not be hurt as bad as you think. Water through the exhaust may be your worst enemy. Try mixing some hydraulic fluid, brake fluid, and some PB Blaster together and fill the cylinders through the spark plug holes. Leave it set a few weeks or months and build yourself a prybar that will insert through the 2 holes in the flywheel so you can turn the engine over. Just try to pry the flywheel back and forth. Don't be dumb and use a loader or forklift to force it, you could cause alot of damage that way. If it doesn't come loose unbolt the rods and and pull the block out with the pistons and rods in it and press them out. A local machine shop should be able to do that if you don't have a press. Make sure you unhook the oil lines inside the crankcase to avoid damaging them. Goodluck with your project it will be well worth it.
TimWafer
07-22-2007 16:44:57
third party image
Well, It might not be your color, but yeah. Ive done one that bad. Wanna see!
John-Paul T
07-22-2007 22:24:12
 Re: Anyone ever redo one this bad? in reply to TimWafer, 07-22-2007 16:44:57
Nice work nothing like a properly done engine. Ah man I got the itch to tear a motor apart and rebuild the moment I saw those pics. Dont know what it is but I think some of you know what I mean. I have a 6cylinder on the engine stand and I need to get the machining done. If only my wallet could keep up with me! haha.third party image
JDDodge
07-22-2007 16:35:48
I have seen tractors ect worse then that one and people have re-done them . If it was me, I would go for it if for no other reason then sentimental value and that you can't buy or put a price on. My 1-1/2 cents worth, good luck.
two cylinders saves gas
07-22-2007 16:28:07
There are alot of old john deeres out there,but tractors with stories behind them are rare. Alot of us tractors guys restore memorys not always just an old tractor. Good luck with the diamond in the rough!
Farmall MD
07-22-2007 16:37:37
 Re: Anyone ever redo one this bad? in reply to two cylinders saves gas, 07-22-2007 16:28:07
Yeah, exactly. Tractors with good ole memories and stories are rare. There are alot of stories about this tractor.
Like that commercial: cost to restore tractor, $4,000, stories and memories that go with the tractor, Priceless!
Lanse
07-22-2007 16:48:37
 Re: Anyone ever redo one this bad? in reply to Farmall MD, 07-22-2007 16:37:37
Heres my add for that $4000
Tractor=free
borrowing a trailer=$100
gas=$400
parts=$2000
breaking/trying to fix trailer=$300
so happy you fix tractor you get loopy and try to lift front end of tractor`
Medicial bills= $800
parts for what you broke= $400
that feeling you cant describe =priceless
MSD
07-22-2007 16:25:24
I've bought running tractors or those that "ran when I backed it in the shed" ones that required a complete tear down and everything needed to be looked at and evaluated. It shouldn't be that tough to get her going again if the pocket book can handle it. Value of the finished project versus cost can sometimes determine if it's worth it.
Farmall MD
07-22-2007 16:32:12
 Re: Anyone ever redo one this bad? in reply to MSD, 07-22-2007 16:25:24
Yeah, that's exactly it, if the wallet can do it. But, to me it would be worth it, cause like I said it was my grandfather's. Plus that's why I'd like to do it over a period fo 3-5 years or so, to lighten the ouch of the wallet. Doug N
07-22-2007 17:03:35
 Re: Anyone ever redo one this bad? in reply to Farmall MD, 07-22-2007 16:32:12
Long term restorations are always good . People seem to restore in greater detail when there not rushed.
BDM
07-22-2007 15:49:58
I know this, the before & after photo's would be astounding :-). But, it might be very do-able. Need to get it apart for evaluation.
