Fuel Bowl
Green Relics
07-22-2007 14:23:07
Hi Guys, Wondering if any one has ordered a fuel bowl from John Deere for the A's & B's, part # AA5334R. I need to be sure the outlet is centered on the bowl, otherwise all my all fuel fittings and controls don't fit very well. I know there are reproduction bowls out there but I prefer to have a positive screw it in type shutoff rather than just a quarter style that the repro's have. I haven't had very good luck with the quarter turn stuff. They seem to leak by with this new thin gas. I think the last bowl I got from deere was screw in shutoff but I can't remember if the stem was centered. Thanks John
Green Relics
07-23-2007 04:28:00
 Re: Fuel Bowl in reply to Green Relics, 07-22-2007 14:23:07
Thanks Pat for the info. I found the site most helpful. I'm going to download these pages and put them with my service manuals. Thanks again. John
P Browning
07-22-2007 16:17:52
John -- Take a brief tour to the JD-H Restoration Site (below), and whence there, look left -- one-click on FUEL SYSTEMS. The site is under some reconstruction, and you may find FUEL SYSTEMS under a drop-down.
I think on page 4 of FUEL SYSTEMS you will see a brief discussion and comparison of original fuel filters with the current Deere replacement. One has the offset (1/2-inch) and one doesn't! For A, B or G tractors, the current Deere replacement should work out okay so far as fuel line connections are concerned, and it IS the kind where you have to turn IN the screw to turn fuel off.
For the "H" tractor, however, there just is not enough room for the change in offset because space for the 3-way valve is already scarce! At any rate, there you will find the discussion you need. (PatB)
