1950 B Block Removal
B Bob
07-22-2007 13:50:15
Have decided to proceed with removing the block to check for cracks and general cleanup. I had posted an inquiry earlier about what has to be disconnected inside the crankcase and am getting mixed feedback about the tappet oil feed pipe connection. Is the fitting bolted to the inside of the crankcase only or is there a direct connection thru the crankcase into the block? Want to make sure everything is free so I don't yank the guts out of the oiling system! I appreciate any feedback.
Green Relics
07-23-2007 06:05:32
 Re: 1950 B Block Removal in reply to B Bob, 07-22-2007 13:50:15
Hi B Bob, The late B will have enough room to get the block out the right side with the studs on the Block with the fan shaft in place, but watch your fingers. It's heavy and not easy to get it just right. John
johns48jdb
07-23-2007 04:06:57
maybe i'm still a sleep 52bman, but are the studs turned up or down? one sentance says turn them up and the next says they should come out first, which means they would be pointed down.
GeorgiaHayFarmer
07-22-2007 17:57:32
third party image
Hay,
You shouldn't have a problem getting the block out. Just give yourself enough room up top to clear so you can pull it out once you get it turned correctly. Watch your fingers and if you can get someone to help you pull it out. Here is a picture of my 1950 B.
Scott
52BMAN
07-22-2007 17:31:21
The oil line is connected inside the crankcase and NOT to the back of the Block. It should come out the right side of tractor. When block if free of studs, turn it so upper water pipe surface is toward the left side of frame. Now rotate it so head studs are facing up. The block should come out head studs first even with fan shaft in place. I copied this from my JD service manual, and I have done this myself.
