How many HP possible n/a 6404D
Hotrod4000
07-22-2007 11:56:06
I would like to know how many HP can be made with a 6404D n/a for pulling? Head work, cams, pump, injectors, manifolds, etc.
low budget
07-23-2007 04:41:33
 Re: How many HP possible n/a 6404D in reply to Hotrod4000, 07-22-2007 11:56:06
Heard of a 4020 that put out 120 with just a little porting and polishing of the head. A few more RPMs would be an easy way to get more power too. Read your other post, you said the mechanic pulled the cover and checked if the shims were removed. Well, the shims are under the leaf spring, you cant see them without disassembling the pump further. I would guess the shims are there and limiting the fuel.
MSM
07-23-2007 01:16:45
Probably the best you are going to do is 125 and that will be a stretch. Anymore than that you need to get alot more air ito the cylinders. Big injectors and maxed out pump, all the headwork,and cam, and all you are going to do is make alot of smoke and no horsepower.It can be overfueled to the point where your horsepower readings start going the other way.Kinda like running a gas engine with the choke pulled out.
Hotrod4000
07-22-2007 16:15:12
Yes I do.
rexhellwig
07-22-2007 13:04:26
Oh, oh.
I'll bet by n/a you meant naturally aspirated, didn't you?
rexhellwig
07-22-2007 12:53:37
third party image
Link
steve-jd4000
07-22-2007 12:28:35
HI Hotrod, wanted ask you if you own a 4000?
