630 rear taillamp ground
fordtech
07-22-2007 07:09:40
the problem is poor ground lights work when jumper is run from bat to reflector shell,I would like them to work with out running a wire to the light. The tractor is not restord ahd the seat is a standerd, any fixs for this, thanks.
fordtech
07-22-2007 17:47:53
 Re: 630 rear taillamp ground in reply to fordtech, 07-22-2007 07:09:40
Thanks for the replies, guys I cleaned the seat tracks real good this time and now the lighit now works it only fiickers a little when the seat is rocked,this is not the best setup for a ground. thanks for the help.
CLW
07-22-2007 09:03:21
I have (had) the same problem. That seat rail just don't ground well to the batt. box. I cleaned it good around where the light to backrest contact is made. Then found an out of site place on the slideing seat rail and ran a wire into the inside of the batt. box and picked up my ground there. At least it is out of sight, out of mind.
MSM
07-22-2007 08:57:02
They were originally designed to ground through the seat frame. Your best bet would be to clean the seat tracks to shiney metal,maybe add a light coat of neverseize and it should work ok.Also make sure the light shell to seat frame itself is clean and makes good contact.If all else fails,you can also add a ground wire from the battery box or battery ground to the upper part(slider) of the seat frame.They tend to lose their ground through the sliding seat track.
