JD 4020 Hydraulic system prescreen?
Blkowboy
07-22-2007 06:29:28
I've been told that some of the John Deere's have a screen that protects the Hydraulic system. I am not referring to the Hydraulic filter in the Oval canister on the JD 4020. Is there such a screen on the John Deere 4020? It supposely is removed by unscrewing a 1/2 drive square nut on the Left side of the tractor. I do see such a nut but have not removed it since it might be some sort of special adjustment.
Glen_in_TX
07-22-2007 11:32:03
 Re: JD 4020 Hydraulic system prescreen? in reply to Blkowboy, 07-22-2007 06:29:28
There is a screen on the sump pump in trans behind that plug. Some plugs are different depending on year of tractor and which trans. You'll be draining all the oil out to change, replace or clean it though so be ready with enough buckets and drain pans. The screen will be metal or plastic and you'll probably need a new gasket for the plug and maybe a new screen too. No special adjustments just get hold of the screen with some needle nose pliers and work it out. There might be sharp metal pieces and worn brake lining crud stuck in or around it from abuse and wear if it hasn't been cleaned in forever so be careful to not cut fingers up. View the 4020 parts catalog and screen by scrolling down at JD Parts to JD Parts Catalogs and then enter 4020.
Nylon
07-22-2007 20:33:49
 Re: JD 4020 Hydraulic system prescreen? in reply to Glen_in_TX, 07-22-2007 11:32:03
I still can't seem to get anywhere near a 4020 on jdparts. In the drop down when you try to click on parts cat it says it has data and views back to '75. Anything older and you gotta see dealer.
HTR
07-23-2007 09:05:08
 Re: JD 4020 Hydraulic system prescreen? in reply to Nylon, 07-22-2007 20:33:49
Type 4020 in here.
Glen_in_TX
07-23-2007 09:02:06
Nylon, Just bookmark this page to take you to parts catalogs. You'll have be signed in and registered with a local dealer at the the main JDparts page to use shopping cart or price parts though. You shouldn't even have to be registered or signed in to view the parts catalogs. Make sure you are entering it in the model search box and not part where used or some other search. They are revised parts catalogs as Bob said and don't always give casting numbers or show other older substitute numbers. The wheel weight I was trying to ID for someone else was proof of that as more research it showed another weight of different number but never gave a sub part number reference or if they truly interchange. When in doubt on that visit your dealer.
Bob
07-22-2007 20:44:48
What they mean is partsbooks REVISED after 1975 are on the jdparts site.
AFAIK, ALL the "newgen" stuff (basically 1961 and newer) is up for viewing on JDPARTS.
