4020 pto brake
5020s rock
07-21-2007 21:39:27
hi--i am ready to reassemble the clutch for
a 4020 synchro. the clutch,housing and components
were rusted badly(?) what is the travel of the pto brake plunger...does it only travel inward
(towards the rear of tractor). the it manual was not clear, also what does the brake slow? the
thru shaft? thanks
lonzo
07-24-2007 02:10:37
 Re: 4020 pto brake in reply to 5020s rock, 07-21-2007 21:39:27
the pto brake hardly moves at all, when you pull back on the PTO lever the brake is applied by a tab that is on the bearing yoke. take the bottom cover off and have so one work the pto lever and you will see what is going on. the brake stops the shaft from turning when your not useing the pto
