JD 4020 Leaking Hydraulic fluid near clutch plate
Blkowboy
07-21-2007 04:52:10
My John Deere 4020 Has starting leaking Hydraulic fluid when running from where the clutch cover plate is located at the bottom not far from the oil pan drain bolt. When I take the cover off I can't see exactly where its coming from. Is this a major major split the tractor or is there a possible quick fix.
Tx Jim
07-23-2007 04:10:13
 Re: JD 4020 Leaking Hydraulic fluid near clutch plate in reply to johns48jdb, 07-21-2007 04:52:10
Blkowboy if the tranny shifter makes a "J" not a zig-zag pattern its a powershift plus synco-range tranny's don't have 4 reverse speeds. Tx Jim
jdemaris
07-21-2007 06:19:39
 Re: JD 4020 Leaking Hydraulic fluid near clutch plate in reply to Blkowboy, 07-21-2007 04:52:10
It it has a SynchroRange trans, and is a later model 4020 - the PTO engagement pistons can leak a lot - in that area - if you've been using the PTO at all.
Blkowboy
07-22-2007 06:55:26
 Re: JD 4020 Leaking Hydraulic fluid near clutch plate in reply to jdemaris, 07-21-2007 06:19:39
I don't know if it is a synchorange transmission.It has a shift on the column 8 speeds forward + 4 or more speeds for reverse. How can I tell ?
MSM
07-21-2007 05:41:21
If it is leaking from that area it will have to be split to replace the input seals on the trans shaft. Also check the pilot bearing while it is apart,if the bearing has self destructed it allows the shafts to wobble and the seals leak. I have seen a steering valve leak on an old style 4020(non console) run down the pto actuating rod, and into the bellhousing,as well as around the bellhousing. Maybe a little more checking might be in order.
