From what I read, the engine idles okay but will not pull, will not come up to a load. Let's try a few simple things & see what we learn, then please post back and we can go from there. 1. Ensure adequate fuel supply -- with fuel valves open & holding a collecting can under the carburetor, open the drain cock and you should have a steady, uninterrupted flow of fuel with stream diameter somewhere around 3/16 to a quarter inch. Some describe it as "pencil" diameter. 2. Check the LOAD needle. See what it is set at. This one should be just under one turn out. It may be at full IN which would deny LOAD fuel to the engine. 3. Just to be sure -- I would ask you to make a quick check of the governor-to-carb linkage adjustment. "With the hand (throttle) control in full speed position (engine not running), adjust the length of the carburetor throttle rod so that the rod is 1/2 hole short from entering the hole in the carburetor throttle shaft lever when the carburetor butterfly is in wide open position. Reconnect throttle rod at carburetor." 4. Go to the JD-H Restoration Site, look left & select CARBURETORS. Once there, go to page 9 of that document where you find a no-wrench test for your carburetor -- tests each of the two pathways to ensure there is no blockage. 5. Alien critters can get into the darndest places. Ensure adequate air supply to the engine through the air cleaner. You can lower the oil bath cup or open a gap between carburetor and air inlet elbow to see if there is a difference. Be careful here as relates to backfire. More later (PatB)
