Electrical schematic for JD 3300 Combine
Larry O'Grady
07-20-2007 14:32:05
Wondering if someone would know how I could get a copy of the schematics for my 3300 JD Combine. I just rebuilt the engine and when I first started it, my starter motor didn't disenguage and it burnt out. Before I install the new one, I'd like to make sure my wiring is all correct.
Thanks,
Larry
wilamayb
07-20-2007 16:10:43
 Re: Electrical schematic for JD 3300 Combine in reply to Larry O'Grady, 07-20-2007 14:32:05
Bob had a good thought, and make sure that your alternator is not feeding the actuator (S) post of your solenoid. If it does it will be enguaging your solenoid any time the alternator is charging.
Bob
07-20-2007 15:53:10
If it's a "gasser", be sure you have only 1 wire on the "S" terminal of the starter solenoid. The second wire, the ignition resistor starting bypass, goes on the solenoid's "R" terminal.
Larry O
07-20-2007 17:44:44
 Re: Electrical schematic for JD 3300 Combine in reply to Bob, 07-20-2007 15:53:10
Thanks for the replies. It is a gas (202cid). It also has a fuel shut-off solenoid on the carb. I had it hooked up to the solenoid and as a result it only stayed open when in the ignition was in the "start" position. I have to find another power source for this. I'm picking up the new started tomorrow am and will look for the "S" and "R" symbols on the solenoid. I also have a wire coming off the solenoid to the distributor. What does this do and which terminal does this belong on? I wish I had the schematics for this machine.
Thanks again,
Larry
Dingaling
07-20-2007 19:02:20
 Re: Electrical schematic for JD 3300 Combine in reply to Larry O, 07-20-2007 17:44:44
Larry, I have the schematics for that machine ,will dig them out tomorrow and e-mail..... ..Joe
Larry O'Grady
07-21-2007 16:00:29
 Re: Electrical schematic for JD 3300 Combine in reply to Dingaling, 07-20-2007 19:02:20
That would be a great help! Thanks for the offer. Larry
