Deere H Rod Strength -beefy?
Mopower
07-20-2007 07:42:58
I am considering using model H rods in my small 4cyl Moline pulling engine. The dimensions work out well for an offset grind. My 1939 Deere H runs maybe 1500 rpm max with stock 4.25:1 compression ratio making 12-14 hp. In the Moline engine I may run up to 2250 rpm at 12:1 compression making hopefully 90 hp (well 45 on two cylinders haha). I know Deere builds things heavy like M-M, but will the rod hold up in this application?
105CS
07-20-2007 13:57:30
 Re: Deere H Rod Strength -beefy? in reply to Mopower, 07-20-2007 07:42:58
A waste of four good connecting rods.
Mopower
07-21-2007 13:51:17
 Re: Deere H Rod Strength -beefy? in reply to 105CS, 07-20-2007 13:57:30
Nah, only a waste of two. I thnk I have two already in an H skeleton.
P Browning
07-21-2007 16:25:45
 Re: Deere H Rod Strength -beefy? in reply to Mopower, 07-21-2007 13:51:17
When & if you need a couple more JD-H conn rods, give Russ a call (816) 587-4747 [Paul's Rod & Bearing] AKA Heartland Tractor Parts.
P Browning
07-20-2007 10:08:31
 Re: Deere H Rod Strength - beefy? in reply to Mopower, 07-20-2007 07:42:58
Give Russ a call over at Paul's Rod & Bearing -- (816) 587-4747 -- share with him some of what you plan to do. He has been into engines all his life -- this IS his life and he will have some good responses for you. (PatB)
Mike M
07-20-2007 07:52:16
Only one to find out ! Put some in and try it and if you live through it come back and give a full report.
Mopower
07-20-2007 08:36:58
 Re: Deere H Rod Strength -beefy? in reply to Mike M, 07-20-2007 07:52:16
I may do that. I'm sure no one else is stupid enough to try such a wierd contraption. If you don't hear from me again, I'm laying with a Deere rod through my skull. At least I can't blame Moline for it haha.
Mike M
07-20-2007 11:24:39
 Re: Deere H Rod Strength -beefy? in reply to Mopower, 07-20-2007 08:36:58
I've heard all kinda weird stuff pullers do with welding,splicing rods,cranks,and thinning cams to clear cranks. So what you plan sounds good.
