G clutch driver???
Ning
07-19-2007 20:04:33
Is there a secret to pulling the clutch driver off an unstyled G? I've tried a gear puller but am afraid I'll breake the driver if I put too much pressure on it. Thanks for any help.
Green Relics
07-20-2007 11:09:24
 Re: G clutch driver??? in reply to Ning, 07-19-2007 20:04:33
Hi Ning, You need a good serious puller. As big as you can get in the slots or you can use good grade 5 or better square headed bolts in those same slots to push the driver off. I've had better luck with a big puller and then put real good tension on it then rap the end of the puller screw with a big hammer. Wear safety glasses and watch your toes because when it comes off it's a heavy hunk of iron. Good Luck. John
