JD 2640 galloping
Dieselrider
07-19-2007 15:59:00
I have a JD 2640 70 horse. The last several times out (mostly brush hogging) every so often the engine will slow down and then it wants to gallop fast and slow for a few seconds like there might be a spring in the governor getting weak or and it has trouble finding a "steady" spot or something. Has any one ever had one of these do this and what if anything can I do about it?
wilamayb
07-19-2007 16:40:12
 Re: JD 2640 galloping in reply to Dieselrider, 07-19-2007 15:59:00
So you either have air entering the system, a lack of fuel to the injector pump when called apon, or your pump governor is actually surging and sticking. I'm afraid the latter might be the problem.
Have you been running any ultra-low sulfur diesel in the past little bit? Certainly may not be your problem, but it does cause serious problems for these older machines. It's lubrication qualities are out the window on these older pumps with large tolerances.
Have you changed your fuel filter in the very recent past?
If in fact your pump is causing the problem. Some folks here will say that the pump is in need of a rebuild, which may be true. At some point the gov may stick at wide open throttle overspeeding the engine. It's always a good idea to have something to "choke" the air off to the engine in case of an emergency shut down.
My suggestion would be to add a couple gallons of automatic transmission fluid to your tank, or get yourself a can of the Stanadyne lubricant for using Ultra-low with older machines. You should be able to get this at your local diesel shop, or at least a similar product. Mix it stronger than stated until things get slicked back up then return to the suggested amount. This slickem up fast has fixed a few pumps, but yours may be past fixing? You dont know till you try, and its a heck of a lot cheaper than a pump rebuild.
