JD 50 FUEL IN OIL
BRETT JONES
07-19-2007 12:09:09
I HAVE A JD MODEL 50 AND I AM GETTING GAS IN THE OIL CRANKCASE, CAN ANY ONE TELL ME WHAT IS CAUSING THIS AND HOW TO CORRECT IT?
zwr
07-19-2007 18:19:44
 Re: JD 50 FUEL IN OIL in reply to BRETT JONES, 07-19-2007 12:09:09
Don's right, but you may also need to know that if the diaphram fails it allows fuel to continue to be available to the carb even tho you've shut the engine off. If the needle valve in the carb float chamber also fails, fuel runs by gravity down thru the carb and past the pistons into the crankcase.
I learned the hard way, too.
jeep65
07-19-2007 13:02:21
The diphram that shuts off the fuel with oil pressure probably has a hole in it.They are on top of the sediment bowl. They are avaliable from the dealer as I just replaced mine in a 520. Not too hard to do but you have to take the sediment bowl unit out of the gas tank to replace them.
Don
