200 series cultivators
R Matthew Songe
07-19-2007 08:36:15
I drive one of those 'other' green tractors and bought what was advertised as Oliver cultivators off eBay. When they were delivered I found out that they were JD cultivators, most likely series 200 2 row.
I do not know which tractor they are for. From reading discussions here and around the web, I do not believe them to be the quick attach type. They have a two bolt flange and a 1 1/2" square bar stock main support. I did not get any kind of stanchions for mounting/dismounting. I did get 4 fenders and the adjustable pipes that go down the side of the tractor.
How can I find out what tractor these are made for? How can I find out what else I may be missing?
My intentions at this point are to free up anything that may be frozen, repair the fenders, find any missing parts and see if any of the local (Southeast US - North Georgia) 2 cylinder gangs might be interested. Any help, advice or pointers are welcome.
Will P
07-19-2007 14:39:03
 Re: 200 series cultivators in reply to R Matthew Songer, 07-19-2007 08:36:15
You could have the 220 series cultivators made by Deere. They bolt to the sides and have square tubes that hold the gangs. I have 227 cultivators on my 43B They may not be 200 series.
Do you have the rods that go from the outer corners of the frame to the center of the pedestal? If you do, what are the numbers on the rods. They are stamped. 200 series are longer than the 220 series.
Will P
R Matthew Songer
07-23-2007 06:16:39
 Re: 200 series cultivators in reply to Will P, 07-19-2007 14:39:03
The long rods have 29576 stamped on them. The short rods have 29577. the clamps on the 1 1/2" pipes have H-393-A cast in them. The fenders are like tents with some scissor arrangement of flat stock suspending them from a right angle bracket that has a u-bolt, rather than two separate blades. I can"t see where on the parts that I have that they would mount. Any more clues are appreciated.
R Matthew Songer
07-20-2007 07:57:46
I think that may be it. Thanks for the info. I've been looking at the numbers on the clamps and trying to find some indication from those. I took some picture this morning. I'll post in a little while.
Will P
07-20-2007 16:34:46
 Re: 200 series cultivators in reply to R Matthew Songer, 07-20-2007 07:57:46
The reason I know about the rods. I have the cultivator manual for the 220's. I was missing one rod for the cultivators. When I questioned my Deere dealer. Rod no long available. So a rod for the 200 series was available ($20.00). So I got it. Long by a foot. I can get pictures of my cultivators tomorrow. I will measure them too. They are on the tractor.
Will P
Mike Aylward
07-19-2007 12:59:22
Matt, to the best of my ability, here are some ways to tell what you have. The 200 series cultivators use chains to adjust the fenders which are frame mounted. The later 20 series has rig-mounted fenders. On the 200 series, assuming it is a Quik-Tatch mounting, the mounting plates for the A-B-G tractors is straight, meaning the top and bottom are parallel. If the mountings are for the later tractors (50-60-70) the mounting plates will be wider in the middle of the plate. On the plates that connect the lift linkage with the rig pipes, on the 200 series cultivator they have straight rear edges and the H cultivator has curved rear edges (or at least the ones I have do). A cultivator for an MT will have the lift pipes fastened to a bracket on the bottom of the cultivator cross frame whereas the others use a bracket on the top of the cross frame. Perhaps this will give you something to go by. Hope this helps. Mike
R Matthew Songer
07-19-2007 13:24:34
 Re: 200 series cultivators in reply to Mike Aylward, 07-19-2007 12:59:22
Thanks, this helps a lot.
The mounting flanges are diamond/oval shaped. All the edges on the plates are straight and the fenders have U-bolts that are shaped for mounting to square or rectangular bar stock. I will look at the other characteristics you mention when I get home this evening.
I swear, working a straight job sure does put a dent in my tractorin' time, but when you're addicted to food, shelter and clothes, what can you do.
Len Bull in NC
07-19-2007 08:49:11
Matt:
I assume from your description that they mount in or on the front (actually sides)of the tractor? The two pipes are the lift rods and should have a clip on one end and a collar with an adjustable set screw on the other? That pipe slides into a ring on the PowrTrol lift arms on each side of a JD 2 cylinder tractor and lifts the cultivators. The clips connect to the little curved flat bar on the top of the cultivators and serve to leverage the lifting. There should be a set of either two rods with flat slot openings or with both sides of the cultivators connected together with a rectangular frame that mounts on the front of the JD using the 4 big studs in the front frame of the tractor.
The cultivators themselves mount on the side of the tractor in two of the set of holes on each side. The cultivator frame has a plate with one hole and one slot, as I remember (it has been 40 years since I last mounted those!)
If you are lucky you also got a set of two rear gangs that connect to the bottom of the lift arms with a chain and clevis. There is a hole in the bottom of the lift arm below the ring that the pipe slides into that they connect to.
Once you do all of that..you are in business!
LEN
R Matthew Songer
07-19-2007 09:33:25
 Re: 200 series cultivators in reply to Len Bull in NC, 07-19-2007 08:49:11
I did not get the rear gang.
The long pipes have slots with offset flats at either end and both ends are threaded into the pipe body. Near one end of both pipes is a small piece of round stock passing through the pipe to be used as a handle. The tractor side mounting flange has two holes.
What are the differences between the B-200, H-200 and any other ?-200 series cultivators that may exist? I just want to know what I have so that I can attempt to sell them to someone who can use them.
Len Bull in NC
07-19-2007 12:12:57
 Re: 200 series cultivators in reply to R Matthew Songer, 07-19-2007 09:33:25
Check this site: It has a B-200 series, I think.
http://www.retiredtractors.com/Implements/Cultivating1.html
R Matthew Songer
07-19-2007 13:16:49
 Re: 200 series cultivators in reply to Len Bull in NC, 07-19-2007 12:12:57
Thanks, I looked at his site. Good information there. His page is what gave me a clue as to what I might have and what I might be missing. I'm going to contact him and see if he can send me some larger photo files of his rig.
Len Bull in NC
07-19-2007 12:05:04
Matt:
I dont know the answers but I will try to find them.
I realized after I sent my long message that you may not have a JD tractor but rather an Oliver..which is also a good tractor...so all the specific connection stuff is probably not relevant! Sorry!
More later.
LEN
