40W (orU,orS) final drive gear question
jCarroll
07-19-2007 06:33:04
All three of these models use the same final drive (differential to axle) design, if anybody has experience with one, it will work for my 40W.
I have significant wear on the bull gear tooth face in the forward direction. Although I haven't yet seen the pinion gear, I'm suspicous that it is also worn. My question is if these gears can be flipped over on the shaft to make the reverse side of the tooth become the forward side.
Putting the left gear on the right side, etc is obviously doable, but it will be somewhat harder to have both final drives off the tractor at the same time.
Comments/ advice?
Mike M
07-19-2007 07:06:19
 Re: 40W (orU,orS) final drive gear question in reply to jCarroll, 07-19-2007 06:33:04
I flip them all the time in the A and B and larger tractors. But if yours are really bad you may need replacements.
