JD 114-W Hay Baler
Ed Sharp
01-17-2000 19:53:49
I need information on JD 114-W or 116-W wire tie hay baler. This is the old side delivery type. Any help parts or locating books would be appreciated.
R. Marg
10-25-2003 21:49:48
 Re: Suggestions on buying used JD 2555 in reply to Robert Cederstrand, 10-25-2003 19:50:22
I can't tell you much about that tractor but I can give you ideas of what to look for make sure it has good oil pressure , no leaks as in lots of oil on the out side and as far as a baler,round you need a tractor of at least 55HP hope this helps some
Fudd
01-18-2000 17:51:55
 Re: JD 114-W Hay Baler in reply to Ed Sharp, 01-17-2000 19:53:49
Try JD at 800-522-7448 for parts and owners manuals. They had them for my 14-T. Good luck.
