2440 engine help
jamesthomas
07-19-2007 05:55:50
Howdy, I have a 2440 with a 4219 diesel engine. The other day, we noticed that oil was getting into the radiator, but it did not appear that coolant was entering into the oil pan (oil was not milky). We are wondering what this is attributed to; cracked head, block, bad headgasket?
ben brown
07-19-2007 10:06:01
 Re: 2440 engine help in reply to jamesthomas, 07-19-2007 05:55:50
under the engine oil filter is i belive a engine oil cooler sometime the o-ring under the filter base and cooler go bad
jamesthomas
07-19-2007 09:59:45
No, the hydraulic cooler on that tractor is separate and uses air to cool (separate radiator) the hydraulic oil
Mike M
07-19-2007 09:36:47
Or does that one have an engine oil cooler ????
Put a pressure tester on the radiator and start it up ( cranking over may be enough ) and see if the pressure builds really fast ! be carefull as if it does your head gasket is blown and don't let it go too high as to hurt the radiator.
