720 Tach drive
BLinWMi
07-18-2007 17:53:01
Hey guys, decided I wanted to get the tach on my 720 in order and found that the cable when disconnected at the tach, does not turn. With the diesel running I can spin the cable shaft and feel no resistance. The hood is still on so I do not know if the cable is just twisted off on the lower end or what. In your experiences, is this likely the culprit or is there a bad drive gear inside the governor? Appreciate the help.
Richie Osgood
07-18-2007 19:40:44
 Re: 720 Tach drive in reply to BLinWMi, 07-18-2007 17:53:01
I just put a tach drive gear in my 620 today. The cable was good. I took the cable off the engine and the output was not spinining. I took out the govener and sure enough the plastic tach drive gear was busted. Ordered a new on from John Deere for 20 bucks. Workes great.
GeorgiaHayFarmer
07-18-2007 19:32:57
You can always check the cable first and see what happens, then go to the drive unit. In my case it was the cable on a 720D.
Scott
jdmeyer
07-18-2007 19:11:48
i had the same problem on my 730 d. the gear was broken. not very exp to fix, but had to loosen the pony mtr bolts justo move it alittle bit to replace the gear. good luck
dds-inc
07-18-2007 19:02:59
bad drive gear? no way. It's the cable.
