8.1 liter powertech Conversion
wilamayb
07-18-2007 16:16:01
I have a spare 8.1 liter Powertech engine from a 772CH motor Grader. I would like to do something creative with the engine. My problem is that the injection pump is supposed to be computer controlled, but I think I would like to have it manually controlled so that it will be easier to mount in a truck. It is somewhat detuned in the motor grader, so having it manually controlled would allow me to meter the fuel as I see fit.
The grader uses a potentiometer throttle control with wires consulting the TCU and ECU and FHC, so in order to rewire I would really have to get into the theory of operation of each controller. Perhaps I could eliminate some of these, but I dont know which ones?
Has anyone done a conversion or found a injection pump that will fit and work with the 8.1 powertech? I searched the parts catalog, but didnt find a powerunit with a mechanical pump.
Does anyone have an 8.1 powerunit that is mechanically controlled?
I guess if I knew where to look I could use the parts from a computer controlled powerunit.
I would love to hear what you have to say!
wilamayb
07-19-2007 14:52:45
 Re: 8.1 liter powertech Conversion in reply to wilamayb, 07-18-2007 16:16:01
Well Thanks to you all!!! Sounds like I have a plan for the injection pump If I'm willing to come off of $2,500 to mother Deere. I may have to get out my wiring diagram and figure out what does what on the elec. controlled pump. I'm pretty dumb, but when it comes to tossing money out the window the light bulb usually comes on.
Now for the clutch and flywheel? Does anyone have any suggestions there? How about a transmission?
Man I've got lots of questions!!
rexhellwig
07-18-2007 18:06:45
wilamayb, How complete is your engine?
Do you already have a pump with electronic governor? Or no pump at all?
wilamayb
07-18-2007 23:47:04
 Re: 8.1 liter powertech Conversion in reply to rexhellwig, 07-18-2007 18:06:45
It is very complete. It is still in the Motor Grader. It runs and Has a good pump with the electronic gov.
K.B.-826
07-18-2007 17:18:10
7710 and 7810 tractors have the 8.1 and a mechanical pump. No computer required whatsoever.
rexhellwig
07-18-2007 17:50:51
 Re: 8.1 liter powertech Conversion in reply to K.B.-826, 07-18-2007 17:18:10
"7710 and 7810 tractors have the 8.1 and a mechanical pump. No computer required whatsoever."
You got a part number for one of those pumps?
Web parts link
K.B.-826
07-18-2007 20:46:33
 Re: 8.1 liter powertech Conversion in reply to rexhellwig, 07-18-2007 17:50:51
Yes I do. For tractors below serial number 29999, RE64420 for 7710, RE64421 for 7810. These are Denso pumps with a mechanical governer. I should have been more specific in my first post, as these tractors do use pumps with electronic governers when equipped with the AutoQuad or IVT transmissions. I'm mostly around early model powershift 7810's. Now, back to the original question about installing this engine in a truck. Why not just use any old Bosch A pump from a 466?
rexhellwig
07-19-2007 04:20:37
 Re: 8.1 liter powertech Conversion in reply to K.B.-826, 07-18-2007 20:46:33
That's right. And thanks for the reply.
Your original post sounded right, {But faulty memory and laziness on my end made me doubt}
A mechanical governor pump that uses his original injection lines is probably going to be his best solution. His good elec. pump should have some value to someone...Maybe he could do some trading?
