3020D electrical problems
GregC
07-18-2007 11:30:32
I have a 64 3020D that's giving me fits with the electrical system.
None of the headlights or the fuel gauge work when the engine is running above an idle, when I throttle up, the lights get dimmer until they go out, and the fuel gauge quits working. If I just turn on the key, the gauge and lights work. Any help would be appreaciated.
GregC
07-18-2007 16:33:44
 Re: 3020D electrical problems in reply to GregC, 07-18-2007 11:30:32
So that's where that wire came from!!! I found it laying in the battery box when I replaced the batteries. I'll replace it when I get home. Thanks Bob
GregC
07-18-2007 16:31:38
Bob
07-18-2007 12:38:42
You are lacking chassis ground, from the midpoint of the 2 batteries, to the tractor chassis. This could be because of a wire missing, or simply a blown fuse. You don't happen to see a small ground wire, posssibly with a fuseholder, in one of the battery boxes, do you?
