JD 4020 Creeper gear?
Steeny
07-18-2007 08:16:36
Is there a way to slow down my 4020? I need to travel 25-35 ft/min. Any Help?
Chad
Gerald J.
07-19-2007 09:28:49
 Re: JD 4020 Creeper gear? in reply to Steeny, 07-18-2007 08:16:36
Mount a hydraulic pump on the front PTO shaft. Replace the front axle with a rear axle from a combine with hydraulic motors on the wheels. Choose the pump and motor displacements to get your desired ground speed with the PTO at 1000 RPM. Be sure to allow for oil circulation when not using the front hydraulics. You will need a significant reservoir to cool the oil.
Gerald J.
buickanddeere
07-18-2007 19:08:25
Just about all of the 5000 and 6000 vintage Deere's offer a field bolt on creeper transmission. Don't know about the 7000's. You can't teach an old dog new tricks.
Nathan (SD)
07-18-2007 15:27:21
Don't know what you are doing but a Ditch Witch can travel that speed or maybe even slower. They are built for glacier speeds.
squirrel
07-18-2007 11:26:53
Look at the older IH Hydro's, or if a compact frame tractor will work, several companies make 30-45hp hydro trans versions. One neighbor has a IH 656 hydro, he can set it to where you have to stare to see if it even moving. But I hear they are expensive to repair if they have issues. Another option is a custom cut gear. A lot of tractor pullers get a gear cut for between 7 & 8, maybe you can get an ultra slow gear cut...
wilamayb
07-18-2007 09:06:52
I dont know what your horsepower requirements are, but the most of the Jap. tractors have speed capabilities like what you are speaking of. Some will go half the speed you need. Many folks are not fond of the Yanmars, but parts are readily available. I've had a couple. They seemed to be fuel efficient and durable from my experience. I think you can get up to 45 HP or so with these models.
Gerald J.
07-18-2007 08:51:51
You might mount drive track assemblies off a Case-IH Quad track where the track drive sprockets are much smaller than the tires and get the slow speed that way.
Gerald J.
MSM
07-18-2007 08:44:25
I don't think there is anything you can do to a 4020 to get it that slow,even idling with 14x28 or 16x30 rear tires .Even a 4230 or 4430 with a creeper trans won't get down that slow.Your only recourse might be a red tractors with a hydro (70 hydro), or spend a whole pile of money on a Fendt or Deere with the IVT trans.
