G/MAN
07-18-2007 15:49:59
Re: 2520 Oil in reply to Ferd, 07-17-2007 17:35:37
It may very well have been overhauled and not broken in correctly. That's pretty likely in fact, particularly if the overhauler isn't up to speed on the current situation with diesel oils and rebuilt engines. And a lot of guys aren't - I had to go back into a 3020D that was overhauled by a local independent guy a few years ago. The quality of his work was fine and I like the guy, but he simply didn't know what he was doing when it came time to fire the tractor up and put it to work. Dumping any of the modern high-quality heavy-duty diesel oils - Deere Plus-50, Shell Rotella, Mobil Delvac, etc. - in a new or rebuilt engine these days is asking for trouble to start with, and if you don't take the tractor out and work the heck out of it, that just compounds the problem. The new oils are so good at preventing wear that they won't allow the rings to seat properly in most conditions. That's why Deere recommends Break-In oil for all rebuilds and why they put it in all their new engines as factory-fill. Several hours of varying loads up to and past full load on the dyno is ideal, idling should be limited to a few minutes to warm the engine up and a few minutes to cool it down, and you always want to use Break-In oil for at least 100 hours, and try to keep working the tractor as hard as possible during that period. The Break-In oil is light on anti-wear additives and is a slightly thinner oil than 15W-40, so it will allow the break-in process to occur and still protect the engine. It takes heat and pressure in the cylinders to seat the rings, and you don't get nearly enough of either idling around or pulling light loads. Another 100 hours of Break-In oil is also a good idea, particularly if the engine is still using some oil. After 200 hours, if the oil level is staying up there, you can go ahead and switch to your diesel oil of choice. Where you're at now, and if the engine has in fact been overhauled and the problems are a result of improper break-in, your only real option is to tear the engine down, hone the holes out good, put in new rings and start over. We've tried to go back to Break-In oil and some dyno time to cure post-overhaul oil consumption, but it really doesn't work. I suppose you could also try the old Bon-Ami trick of sifting some into the intake in order to get some abrasive action between the rings and walls, as some diesel engine builders use to recommend that way back when for curing oil consumption after overhaul, but I can't say it's something I'd do to an engine of my own.
