70LP ELECTRICAL PROBLEM
TEXASJ
07-17-2007 17:34:09
put new battery on tractor and new ground cable. engine does not turn over to quickly. previous owner had done a "homegrown" 12v conversion. Just looking for some insight and need to know where to go from here. Thanks fellas.
texasj
07-18-2007 13:42:17
 Re: 70LP ELECTRICAL PROBLEM in reply to TEXASJ, 07-17-2007 17:34:09
Thanks guys, great help! I will start into it this weekend. Had this tractor a year now and im very anxious to hear it go "pop pop". lol.
txasylum
07-18-2007 08:35:47
I restored a 70LP back in December. It is a 12 volt system with a 6 volt battery and ballast.
I had a week turn over, had to replace the ground and positive cables. They were corroded within itself that it affected the transfer of the voltage. Of course, like others have said, make sure you have a good battery with high amperage. Another problem could be with the starter!
John T
07-18-2007 05:20:14
Tex, On that size tractor I use like a 1000 or more CCA single 12 volt battery which should crank it fine provided the starter and switch and grounds n cables etc are alllll lll okay.
I suggest you remove, clean n wire brush n reattach each n every battery n starter n ground cable n switch conenction. If its grounded to any thin wimpy or rusted sheet metal like a battery/seat box, you might try re grounding to a heavy soil frame type bolt.
If it has working lights turn them on n crank her over n observe how badly they dim down. If they dont dim much the starter could be bad or the starter switch or solenoid be faulty. If they dim wayyyyy yy down I suspect more of a starter problem. If they go all the way out there could be a bad corroded carboned up or loose connection.
If the switch n alllll l the cables n grounds n battery are alllll l okay, that of course leaves a faulty starter motor (ifffff ff the engine is free), but Id try all the easier simple cheaper fixes first. If it has a 6 votl coil and an external ballast resistor the starting spark energy is improved if it has a working ballast by pass starting circuit.
John T
matthies
07-17-2007 20:42:17
Sounds like you only used one battery. How many CCA's does it have? Is you ground cable going to the seat frame and maybe is a poor connection with the rest of the system. Try using a jumper cable and ground the battery at a different location. Or is your starter need rebuilding?
Tom43
07-17-2007 17:48:55
What do you mean by "home grown" 12 volt conversion? The 70 came from the factory with a 12 volt system. the first place to begin is with a load test on your batteries. Most auto parts stores will do this for you free.
texasj
07-17-2007 17:53:30
 Re: 70LP ELECTRICAL PROBLEM in reply to Tom43, 07-17-2007 17:48:55
the ign coil says 6v. he gave me thr oem gen that he had replaced with a delco remy. the guy was an electrian so i guess that explains all the conduit running around. how many cranking amps do i need?
Tom43
07-17-2007 18:52:51
 Re: 70LP ELECTRICAL PROBLEM in reply to texasj, 07-17-2007 17:53:30
Dear texasj,
The gas first numbered series(50, 60, and70) used a 12 volt coil, however, the LP tractors while a 12 volt system run the distributor off the cam shaft instead of the governor shaft. the LP tractors use a 6 volt coil with a ballast resistor and a resistor bypass for easier starting. If your tractor still has the cast iron generator it should be positive ground, but if it has an alternator added it must be negative ground.
If you use a single battery you should have a high capacity battery with about 1000 cold cranking amps. If you still have slow cranking, you need to measure the voltage across the battery terminals while cranking. Then you need to take a voltage reading at the starter while someone is cranking it for you. The starter voltage should be within .3 volts of what you measured at the battery. If it isn't you need to clean the connections or possibly install a new cable.
If you still have problems I would suspect the starter itself, loooking for such things as bad brushes, worn brush holders , or worn starter bushings.
