J-D 70 lower water pipe, (need a source)
big al's acres
07-17-2007 16:22:49
Does anyone make these lower water pipes new? I can go ahead and cut mine then splice with hose. I could also weld on a new end to give me back the length needed. I would just as soon buy a new item if possible. Give me a reference if you have one. Tractor pulls are coming and I can't go running the coolant out a leaking lower water pipe.
Thanks, Alan
Steve Crum
07-17-2007 21:26:15
 Re: J-D 70 lower water pipe, (need a source) in reply to big al's acres, 07-17-2007 16:22:49
If you can get me the dimensions of the pipe, I can probably make you up one out of stainless.
I have dimensions for most of the number series tractors except the 70 gas with the 1055 R pipe.
Brent in WI
07-17-2007 19:25:03
It looks like they are still avaiable from Deere.
Part Number: F1055R Part Price: 57.00 USD On Hand: 0 Check Other Stores Description: PIPE,LOWER WATER
Big Al's Acres
07-17-2007 20:24:06
 Re: J-D 70 lower water pipe, (need a source) in reply to Brent in WI, 07-17-2007 19:25:03
Hey Brent, I hope you are right but my J-D parts guy just told me today that the lower water pipe is no longer an active part??? Does any one else have another idea?
Regards, alan
Mike M
07-18-2007 07:27:08
 Re: J-D 70 lower water pipe, (need a source) in reply to Big Al's Acres, 07-17-2007 20:24:06
Sounds like you need a new parts guy ?
K & K antique tractors may also have that tubing of the correct size. JD uses odd ball sizes. I got a section from them for an upper on a 50 once. I didn't have the fancy rolled edge but I tapered it and use silicone sealer on the o-rings and they slide right in.
wilamayb
07-18-2007 04:57:03
Big Al, I just checked JD inventory. It looks like there are 40 of them left at the Milan Depot if F1055R is the right number.
Tell your parts man to get on it. Tell him you know there are 40 of them in Milan. He'll say "how'd you know that"
