1530 Injection Pump, how to remove??????????
kw650
07-17-2007 14:32:52
My pump went bad on my 1530, and I can not figure out how to take it off. I unbolted it but it will not pull out. Any one know how these little bugers come off? I have a manual on order, but I am realy in a crunch to get it off and sent in for over hall. Then all I have to do is figure out how to time it. Need to get the hay cut. What fun! Thanks for any help!!!!!
Tx Jim
07-18-2007 03:49:34
 Re: 1530 Injection Pump, how to remove?????????? in reply to mike3320, 07-17-2007 14:32:52
kw650 there;s a timing pin on clutch housing. Unsrew and insert in hole in flywheel at #1 TDC. As previously stated remove small front plate on timing gear cover,then unbolt pump shft from gear. Tx Jim
wilamayb
07-17-2007 17:33:20
 Re: 1530 Injection Pump, how to remove?????????? in reply to kw650, 07-17-2007 14:32:52
If the 1530 has a dubuque engine.... Which I'm assuming it does. You will have to remove timing gear cover and remove the nut off the front of the gear driving the pump. Usually its a good idea to line up those timing marks before removing the pump.
Just what you wanted to hear I'm sure. And you thought this was going to be an easy job.
kw650
07-17-2007 17:43:28
 Re: 1530 Injection Pump, how to remove?????????? in reply to wilamayb, 07-17-2007 17:33:20
thanks,
but it has the Frenchy diesel. So it may be different. What a weird combo. German tractor and French engine. Something wrong with that. LOL
wilamayb
07-17-2007 19:41:47
 Re: 1530 Injection Pump, how to remove?????????? in reply to kw650, 07-17-2007 17:43:28
Well sorry then. I cant help you with the European version. Were there US 1530's with Dubuque engines?
