Yes, I did power that circuit with the wire disconnected at the fuel shut off switch, there was no significant arc like a short, just a quick blue spark as I made the connection, and while plugged in, nothing got hot, so I assumed that fuel shut off solenoid to have been bad, most likely due to the screw he put in, he won't live that one down anytime soon I'll bet, but hey we're all human here, and I've done worse things in life myself, but it figures that it turns out to be a little expensive in this case of this particular part. Gerald J, mentioned this on the tractor talk board, but probably no need to do that, (cut the needle) as it's up by the garage now anyway, + I noticed it seems to run rich when throttling up, always some carbon soot, but I'm not familiar with how this 4 Cyl. is supposed to run when properly tuned. If I was to do that, it may stay like that if it runs, my preference is to do the right job at all costs, and I'd hate to worry about him running something cobbed up as well, just not my way of doing things. I 'll mention that as well, should have taken some information if they would have given it out. I agree, most dealers will do that for you, heck one of the guys at the local Cat dealer, copied an entire manual for me at no charge some years ago for one of my old Cat's, real pleasant people at that counter, and it's always people that make the difference when you need help or am helping someone, this sure does not seem too complicated, just want to see whats what on the diagram, double check the wiring, and also see if the battery is still being drawn down as was also mentioned prior to this incident, much thanks Bob !
