Welding on A head update
Josh B
07-17-2007 07:41:00
Well I ordered the rods from muggy weld and they worked good. We welded on the bottom of the head back on and even filled 4 holes with the rod. We did have a couple of cracks afterwards that were our fault i believe from getting it too hot but then I welded those up. Just for fun we welded up the upper radiator manifold that had the ear broke off. We didn't preheat or post heat it but i did grind a bevel in it for penetration. It made a prettier weld because the cast was thick enough to not burn away with the amps we were using and we didn't have any cracking. Anyway I am taking the head to the machine shop today for a valve job hopefully everything holds.
higgins
07-17-2007 13:43:49
 Re: Welding on A head update in reply to Josh B, 07-17-2007 07:41:00
"I like it when a plan comes together". Way to go on welding that ear - that has implications beyond olde tractors.... let us know the outcome.
