hydraulics on a 320
720 in pa
07-17-2007 06:07:12
wondering if jd ever shipped out 320's with remotes on.i need to put remotes on mine and would like to put on what is supposed to be on,if that was ever an option.if not i can probably rig a valve on.thanks
buickanddeere
07-18-2007 19:26:08
 Re: hydraulics on a 320 in reply to 720 in pa, 07-17-2007 06:07:12
The hydraulics were identical on the 40,420,430,3220,330,435,440& 1010 up to serial # 41,000. In the same chassis style. Hydraulics from 1010's are cheap.
95EB
07-17-2007 18:44:38
Yes, remote hydraulics were available for the 320, the original assembly number was AM3112T for a 320 Standard, or AM3113T for a Utility. 420 Standard and Utility Tractors used the same assemblies. Some of the used parts dealers might be able to help you out with the factory parts, but they won't be cheap. You can tap into the pressure and return lines and rig a valve and outlets that way.
Dave H
07-17-2007 10:31:42
I looked in my reference book and it did not list a remote as an option for the 320.
Double checked the 420 and it did list it as an option.
I wouldn't take that as gospel though.
720 in pa
07-17-2007 11:27:28
 Re: hydraulics on a 320 in reply to Dave H, 07-17-2007 10:31:42
i guess theres no chance a 420 remote would fit a 320 is there? i just bought this tractor and am unfamiliar with the upright two cylinders.thanks
Mike M
07-17-2007 11:48:15
 Re: hydraulics on a 320 in reply to 720 in pa, 07-17-2007 11:27:28
A factory remote set up for one of those 420 models is very scarce. And I don't know what you paid for that 320,but from the prices I've seen them bring you could buy 2 better newer usable tractors. 320 models are very collectable !
720 in pa
07-17-2007 13:00:45
 Re: hydraulics on a 320 in reply to Mike M, 07-17-2007 11:48:15
i paid 2000.00 for it.its in rough shape but runs and drives.the reason i need to put remotes on it is to pull a trailer with hydraulic dump.
its for my wife because she refuses to drive any of my other tractors which all have hand clutches.
Mike M
07-17-2007 13:04:26
 Re: hydraulics on a 320 in reply to 720 in pa, 07-17-2007 13:00:45
Well if it has a vin tag and runs and drives I 'm thinking even on ebay you could get enough for it to buy something like a 1020, 2020 diesel ? I thought I saw some go for around $5,000 rough ?
