4010 weak hydraulics fix....
TimS in Mo
07-16-2007 21:08:27
After removing the rockshaft housing once and looking everything over, taking every fitting and valve off and finally deciding that the transmission pump must be worn out as there wasn't any fluid coming out of the filter housing at all with the filter removed while cranking the engine....
I ordered a new transmission pump, it should be here tomorrow. So tonight I took the seat and rockshaft housing back off and experimented with dropping the transmission pump suction tube down into the main sump instead of down into the hole coming from the screen...suddenly it all worked!
Massive gushing of fluid from the filter housing..
The o-ring in the little fitting at the top of the suction tube that goes into the transmission pump was worn just enough to let it suck air I guess. I used one of the square cross section orings that normally go between the scv valves, it was a very snug fit but I reassembled the suction line and mounting to the pump and it works great, puts out one gallon of fluid in 15 seconds at pto rpm from the filter housing now....
My question is, do I have to get some more of the little bend over metal tabs for the bolts on that fitting or can I use lock washers? The metal tabs broke when I straightened them this last time.
Bob
07-16-2007 21:14:36
 Re: 4010 weak hydraulics fix.... in reply to TimS in Mo, 07-16-2007 21:08:27
The T13857 lock plates ARE a bit pricey, @ about $1.10 each, but I'd use them. Having one of those bolts come out and go through the ring and pinion wouldn't be pretty!
TimS in Mo
07-16-2007 22:19:16
 Re: 4010 weak hydraulics fix.... in reply to Bob, 07-16-2007 21:14:36
It's not the price of them, it's the half hour drive each way to go get them.....ahh well.
Bob
07-16-2007 23:56:02
 Re: 4010 weak hydraulics fix.... in reply to TimS in Mo, 07-16-2007 22:19:16
I was just remembering... the "newer" tractors use special "one-time use" bolts with a nylon locking insert built into the bolt.
TimS in Mo
07-17-2007 07:03:17
 Re: 4010 weak hydraulics fix.... in reply to Bob, 07-16-2007 23:56:02
I called the service manager at the local JD dealer, he said lock washers are fine in that application, as a matter of fact he thinks you aren't supposed to use those metal tabs anymore...
So...that's a relief.
Thanks for your help, Bob.
