CAST IRON CARB 3010
TPIA
07-16-2007 17:42:05
Does anyone know where i can get a cast iron carb for my 3010 that dosen't cost big $ ALL i can find are over $500 , USED WOULD BE FINE ALSO THANKS TOM
Gerald J.
07-18-2007 09:01:41
 Re: CAST IRON CARB 3010 in reply to TPIA, 07-16-2007 17:42:05
The demand for that carburetor is great because so few can make the aluminum M-S work. Even Deere dealers had that problem because in about 1970 or '71 there was a Deere Service Bulletin that said toss the M-S put on the Zenith cast iron carburetor.
Your only chance of finding a used one is to catch a gas new generation Deere comming to the salvage yard. I think you can use the carburetor from a 3010, 3020, 4010, or 4020. At least some places that sell replacements in the $500 range show the same carburetor for all those applications. There might be a carburetor from a gas combine that would work too, but the parts book shows a different carburetor part number. Look for a 302 or a 341 or a 361 power unit. It might have something drastically different like a different direction of throttle plate rotation that I didn't notice.
Then before you mount that used carburetor, go in and replace the float needle and seat. The needle and seat will be worn from vibration and won't seal well which will make the engine run rich. That might help your M-S too, though I think its faults start in the accelerator pump diaphragm and check valves. My 4020 shop manual has a large chapter on repair and adjustment of that M-S carburetor.
Gerald J.
TPIa
07-18-2007 09:48:25
 Re: CAST IRON CARB 3010 in reply to Gerald J., 07-18-2007 09:01:41
Gerald thanke for the info. looks like I'll probably have to go new .T H E co has one for $549 thanks again TOM
