2350 Hydraulics
JCrigler
07-16-2007 17:41:46
I have a 2350 with power (not hydrostatic) steering. When the tractor gets hot an intermittent buzzing sound comes from the hydraulic lines. It gets louder when the steering wheel is turned. Also, when it gets hot the brake pedal will intermittently go all the way down. I have replaced the oil, filter and checked the screen which was completely clean. I have replaced the o rings in the steering valve and the check balls and springs in the brake valve. I have also checked the filter bypass valve and hydraulic pressure. Both are OK. The loader and 3 point hitch work fine and don't cause the sound. The buzzing sound leads me to believe that there is air in the system. Does anyone have any suggestions?
buickanddeere
07-18-2007 19:31:44
 Re: 2350 Hydraulics in reply to JCrigler, 07-16-2007 17:41:46
Did the problem occur when the loader was installed or afterwards? Have you tested the line pressure of both the transmission low pressure system and the high pressure system? Is there any noise from the flow control valve on the side of the transmission?
Tx Jim
07-17-2007 04:01:36
 Re: 2350 Hydraulics in reply to Will P, 07-16-2007 17:41:46
JCrigler,you proably have a hi-pressure internal leak in rockshaft valve. Take hyd filler cap off with 3pt raised,engine running and look for spraying oil. If it has independent valve try running engine with loader disconnected. Tx Jim
backwoodsfarm
07-16-2007 18:14:51
I have a 2555 that did that when I bought it. Even after new filters, screens, etc., it still did it. So I drained all the fluid and replaced with Hyguard straight from JD. LOTS of hours later, it has never made a sound. That was my proof that cheap oil doesn't work in JD tractors.
