Gas in Motor Oil 630 continued...
EH in SC
07-16-2007 16:28:35
Thanks for all the previous help with this one! I have the parts either on hand or coming to rebuild the oil pressure fuel shut off. My question is in regards to using teflon tape or any other thread dressing on any of the fuel or oil line couplings. What is best to do and what is best not to do? Also, do any of you also use a manual shut off between bowl and carb for safe guard and if so what valve do you use? I know one thing, I will not be putting a full tank of gas in this one anytime soon! Thanks for any advise, Ed.
Dale in IN
07-17-2007 19:18:05
 Re: Gas in Motor Oil 630 continued... in reply to EH in SC, 07-16-2007 16:28:35
That knurled nut can be screwed down snug. That will keep it from vibrating. It is there to open the plunger manually when it is backed off.
EH in SC
07-18-2007 11:41:13
 Re: Gas in Motor Oil 630 continued... in reply to Dale in IN, 07-17-2007 19:18:05
Dale, Thank you! I made it by my JD Dealership today and hope to have everything back in place by this evening. Can you believe that knurled nut was ~$15? I guess they saw me coming...<;)?
Mike Aylward
07-16-2007 18:27:46
EH, you only will need sealer on the threads going into the tank. I use #3 Permatex or anymore some anerobic gasket maker. The oil lines do not seal on the threads but on the seat of the fitting. Sealer here will likely be a waste of time. Hope this helps. Mike
Dale in IN
07-16-2007 18:19:22
Make sure you replace both diaphrams on the oil preasurer controll I just went through this with a 530 that only runs in parades and shows. This made the 4th time it happened in just a little over a year. I put a shut of valve in the line just in front of the sediment bowl a year ago. And this time I finally found the diaphrams were bad.They looked like a seive and was letting gas leak through the oil pressure line.
As for the nylon tape throw it as far as you can and forget it. It is nothing but trouble. I have hated that stuff ever sense they invented it. You can use a little teflon paste, but use it sparingly.
As for a gas line shut off valve go to your NAPA dealer and get a brass 1/8 male, 1/8 female npt shut off valve and it will screw right in to the front side of you bowl where your gas line goes in and then the line will screw into it. Then it will be hid and only you will know it is there
EH in SC
07-17-2007 08:09:40
 Re: Gas in Motor Oil 630 continued... in reply to Dale in IN, 07-16-2007 18:19:22
Dale and Mike, Thanks a bunch for the help! I have the diaphragms and am waiting on the small seal for the "plunger" type valve. Also replacing the screen and bowl gasket. How tight should that little knurled nut on the top of the oil shut off be? It was turned about halfway down on the visible threads and unless told otherwise I guess I will put it back in the same position. I was going to replace it, but my JD dealership says it would be ~$15! Unbelievable, so I told them I would get by on the old one!
