Which 202 do you have? If it's an early block with casting #s T23406, T24961 or T26933 - the new sleeves will automatically have the updated configuration to repair an erroded block. Deere did that back in the early 80s. First three cylinder 152s (as used in 350 crawlers, 300 and 820/1020/300 tractors), and first four cylinder 202s (used in 450 crawlers, 440 skidders, 2020s, 2510s, etc,), and the first six cylinder 303 engines (used in 540 skidders, 544 loaders, etc.) all use the same repair-sleeve kits. The original setup was one single black seal ring on sleeve that seated in a counter-bore in the block. It had it's problems. So, Deere came out with the kit - and in reality, the counterbore in the block - that gets eaten up - isn't even really needed. Just use some sealer on it. The new sleeves have three seals - one black ring as the original had, one black ring that is new and seats in a new lower area, and a third orange ring that also seats in a new area and is also designed to swell up and take up imperfections in the block. It will swell as soon as coolant or oil contacts it. That is why Deere tells you NOT to use any oil when installing. The later engines also use three seals per cylinder - but the two extra seals install in the block instead of on the sleeve. Back in the 80s, there was some confusion - because the sleeves for the newer engines - look very similar to the original one-seal sleeves that were first used. Visibly, the only difference is - the first sleeves that are no longer made are square-bottomed, whereas the new sleeves for later blocks are chamfered/sharpened at the bottom.
