2020 hot exhaust
henhawk
07-16-2007 10:51:36
I have a 2020 RU i just purchased with the horizontal exhaust. It seems that I am getting a ton of hot air from the radiator fan on my left side. Is this normal or maybe a heat deflector is missing on the tractor. I have a new radiator on the tractor so their is a lot of air movement.
Doc E
07-17-2007 20:42:31
 Re: 2020 hot exhaust in reply to henhawk, 07-16-2007 10:51:36
Hen, My 2020 has a lot of heat "blowing" back from the radiator too. The dealer has told me that 2020"s run "hot" all the time (even with a clean radiator). In the summer it runs right at the edge of the "red line" (as far as water temp) all the time. Makes me wonder if you could (or should)put in a bigger radiator and/or water pump, and lower the "normal" engine temp.
John
