Driving in Neutral- 1950 B
Brad Bachelor
07-16-2007 03:55:04
I had something interesting happen to me yesterday. I was cutting a pasture, when I wen't to downshift to second gear. Well the darn thing sounded like it was going to stall out when I let out the clutch. Sure enough... every gear I had it in, it would stall out when I let outt he clutch. So I put it in neutral and let the clutch out and the tractor started moving. I ended up getting it back to the barn with it in neutral. It seemed like third gear to me as far as speed goes.
Any Idea whats going on? I haven't had time to get into it yet. Just looking for a place to start.
Thanks,
Brad
Josh in MI
07-16-2007 05:36:08
 Re: Driving in Neutral- 1950 B in reply to Brad Bachelor, 07-16-2007 03:55:04
You are in two gears at once. The shifter could be worn or the snap ring on the shifter might be missing. Pull the trans cover and align all the forks in the neutral position. Make sure the ball on the shifter is not worn out. Re-install in neutral and you should be set.
Brad Bachelor
07-16-2007 10:49:03
 Re: Driving in Neutral- 1950 B in reply to Josh in MI, 07-16-2007 05:36:08
Thanks Josh, I'll look er over tonight
JOHN DEERE 70
07-16-2007 10:56:22
 Re: Driving in Neutral- 1950 B in reply to Brad Bachelor, 07-16-2007 10:49:03
Be careful not to get it stuck in two gears if you have to move it again . My son broke my case on my JD60 . Good Luck
