Clutch Noise
Ol Guy
07-15-2007 14:36:32
After my JD '41 "B" had run a while the other day (with the clutch disengaged) it made a high-pitched squeek (and then continued to run o.k.) and after a few more minutes I heard another squeek. There was no "squeek" noise with the cluth engaged. What's the most likely cause?? TIA
kendak
07-17-2007 11:36:04
 Re: Clutch Noise in reply to Ol Guy, 07-15-2007 14:36:32
NEVER let a hand clutch JD stay still for very long ...roller bearing & bushing is sitting still & crank is turning it WILL wear on the crank plus heat up ...when stopped ALWAYS take it out of gear & pop clutch back in ....Kent
Ol Guy
07-17-2007 14:57:27
 Re: Clutch Noise in reply to kendak, 07-17-2007 11:36:04
Yes, I know, but thanks for the reminder. I'm getting ready to sell this tractor and want to be sure "all is well", so I've let it idle with the clutch disengaged more than usual.
greenmech
07-15-2007 20:08:38
Your clutch bearing may need grease. The clutch has to be taken apart to do this. Ron Mn.
