2030 losing power
Mike Hardman
07-15-2007 12:58:56
I need some help! I've noticed my 2030 losing power during mowing. Not so much on a strait ahead run, but rpm's dropping when I back up, or turn sharply. I'm pulling a 6 foot finish mower, and the grass is not very long. I've gone through it much thicker, but never had the problem before. Thanks for any help.
Mike
msb
07-15-2007 19:31:31
 Re: 2030 losing power in reply to Mike Hardman, 07-15-2007 12:58:56
Check to see if the line from the fuel tank is clean and clear. Fuel should flow freely from the tank if the line is taken off at the lift pump. I assume you have changed the fuel filters already? If this all checks out then I would suspect the injection pump needs rebuilt.
msb
07-15-2007 19:31:27
