46 B sediment bowl
patsdeere
07-15-2007 10:56:13
I took it apart the other day to clean it out and the stuff came out like shoe polish. Eventually I got it all cleaned up and the valve to spin. However, when I look through the top of the metal part and turn the valve knob it seems to turn 90 to go from on to off. There isn't much resistance which somewhat concerns me. Is it supposed to screw in and out or is it supposed to just turn 90? If it is only 90, then should there be some sort of friction/resistance to hold it in place?
Thanks.
BC_2006
07-15-2007 12:06:21
 Re: 46 B sediment bowl in reply to patsdeere, 07-15-2007 10:56:13
Patsdeere - there is a sediment bowl that turns 90 degrees for off and on. Some repro places sell them as more original, but I had one for a couple of weeks and had terrible leak problems (the valve was a cylinder rather than a cone). If you disassemble yours you may find that - once it's worn, I don't know how it won't leak. The kind Deere sells now is a screw in that has a definite off - the sediment bowls on my tractors are all this type (many farm stores sell them also).
