2510 clutch or gear problems?
Tim SD
07-15-2007 08:34:16
Had my 2510 syncro parked on an incline,went to move it and it was hard to shift wouldnt go into any gear with the tractor running but you could shift it into gears when tractor shut off.It's as if the clutch isn't working at all but there is proper tention there.You can also try forcing it into a gear and the tractor wants to surge forward.I removed the shift covers and everything looks to be working.Any advice where to look would be apprieciated.Thanks
p.s.Just made the last payment on it last week!
msb
07-15-2007 19:39:42
 Re: 2510 clutch or gear problems? in reply to Tim SD, 07-15-2007 08:34:16
"You can also try forcing it into a gear and the tractor wants to surge forward" ? Question : With the clutch pedal all the way down?
Tim SD
07-15-2007 20:03:35
 Re: 2510 clutch or gear problems? in reply to msb, 07-15-2007 19:39:42
With the clutch pushed in,it will go into 1st gear and the tractor will move forward but all other gears,it wont engage it does alot of grinding ect.I'm not forcing it hard I don't want to mess it up worse.When I got it into 1st gear the clutch was a non issue it simply didn't work in or out.Should I try and get it in 1st again then apply brakes??
Thanks
G/MAN
07-16-2007 13:40:56
 Re: 2510 clutch or gear problems? in reply to Tim SD, 07-15-2007 20:03:35
Did you pull the cover and take a look yet? Honestly - that's the best first step. There are slots in the flywheel that allow you to look and see what all of the linkage and disk are doing, and you can also get there and try to pop it loose. None of the methods that have been mentioned for driving it and trying to pop it loose are terribly wise, safe or good for the tractor. I'm not saying that they won't work and no doubt people have had success using them, but I'm pretty familiar with those clutches - splitting a 3020 right now for a new clutch as a matter of fact - and trying this, that and the other before even taking a look at the clutch itself is a waste of time. The brakes are not meant to try to stop the tractor while the engine is still trying to move it, and trying it in first gear is going to be pretty much pointless, because the gear reduction in low gear makes it all but impossible for the brakes to stop the tractor. As I said, jamming it into gear is a good way to scrap synchros, and starting it in a high gear isn't too safe, particularly if something would happen fast where you'd want to be able to stop the tractor in a hurry, which may be a little tough with a clutch that won't disengage.
G/MAN - I should add...
07-15-2007 08:56:42
If you end up going into the clutch, make sure it's repaired correctly. New Gen clutchs are NOT cheap to repair, especially if any of the big parts besides the disks need replaced, but skimping is a guaranteed way to make sure you'll be going back into it a lot sooner than you would if it's done correctly. All of the fingers should be replaced - both PTO and traction clutch - if they show any wear at all, along with the release bearings, actuating bolts, finger pins, the PTO clutch release and traction clutch apply springs, etc. There is also a spec for how far the flywheel can be machined. Do not try to cheat there, as if it's taken too far it may be impossible to adjust correctly and end up with proper pedal travel upon reassembly. If the flywheel needs machined and is still serviceable, don't let the machine shop take off any more than is needed to give a flat surface, and make sure they take the same amount off the disk surface and the outer ring where the clutch plate bolts on. There is NO need to try to machine any small cracks or "heat checks" completely out, they won't hurt a thing. Also inspect the starter ring gear, replace the rear crankshaft seal and the transmission input shaft seal, etc. Toss the flywheel on a bench, stack, bolt on and adjust the clutch, mark the plate and flywheel so it can be reinstalled in the same location, remove the clutch assembly, install the flywheel and install the clutch and double-check the adjustment. Make sure the operating bearings are getting grease, etc. When it's back together and running, adjust, check and the free-travel right away and again after a couple hours of operation, and make sure it stays properly adjusted. I've seen plenty of clutches that had plenty of life left in them ruined because the owner let the free travel go away, and then slipped the clutch enough to glaze it and overheat and weaken the springs so that it wouldn't hold even when free travel was set properly. Metallic button clutches used to be the rage, but if the clutch is used a lot - i.e. if there's a loader installed - all they'll do is wear out the flywheel and pressure plate, and flywheels and plates are a lot more expensive than disks. Organic disks are more than adequate in a tractor that size, and the disk becomes the wear part.
G/MAN
07-15-2007 08:40:48
What do you mean by the clutch having the "proper tension"? Is the free-travel adjusted to specs, with at least 3/8" of an inch of pedal travel before the release bearing contacts the fingers with the engine running at about 1900 rpm? Remove the cover on the bottom of the clutch housing and take a peak at the release bearings, fingers, etc. Clutches are wear items, and once they reach a certain point of wear, the require replacment. Or a problem with the linkage, release bearing, fingers etc. could be preventing the clutch from disengaging fully. If you try forcing it and it wants to move, the clutch is not disengaged completely and is still trying to transmit power with the pedal down.
Tim SD
07-15-2007 08:54:55
 Re: 2510 clutch or gear problems? in reply to G/MAN, 07-15-2007 08:40:48
What I mean by proper tension is it has the right amount of travel as per book & it feels the same as it did before problem.Also the tractor worked perfect before it sat parked it did sit for a month or so.Thanks
G/MAN
07-15-2007 08:59:49
 Re: 2510 clutch or gear problems? in reply to Tim SD, 07-15-2007 08:54:55
It could be that condensation formed and there is rust in the clutch assembly and it's "stuck" and won't release completely, especially if it has a metallic traction clutch disk in it. Not an unknown issue with tractors that sit for long periods. Some guys block the clutch pedal in the disengaged position for just that reason, but of course then the pressure springs are kept under high tension for long periods of time. Pull the inspection cover and have somebody run the pedal while you watch what goes on with the release linkage, bearings and fingers. You might have to get in there with a screwdriver or prybar and try to pop the disk or whatever's hung up loose.
Tim SD
07-15-2007 09:15:17
 Re: 2510 clutch or gear problems? in reply to G/MAN, 07-15-2007 08:59:49
G/Man:
Thanks for your insight,I wish you were here to look at it.I am not on the same level as you as far as mechanical skill and terms but I will check into the stuck part.It did sit in an area that had flooded and there has been plenty of moisture for the past 3 months.I get the gut feeling it may be something stuck or hanging up.Thanks
G/MAN
07-15-2007 12:06:56
 Re: 2510 clutch or gear problems? in reply to Tim SD, 07-15-2007 09:15:17
You'll get it figured out once you get the cover off and start looking and poking around. Pretty simple set-up, and Deere provided a pretty big hole to work through. I'd put quite a bit of effort into trying to get it broken loose before you go trying to jam it into gear any more. The synchronizers on the top shaft of the transmission aren't made for that kind of abuse. They're more than adequate to synchronize the tranny when there's no power flow into it, but jamming the tranny into gear while the engine is still putting torque into the transmission is just inviting synchronizer damage and further repair, not to mention it's hard on the shifter, linkage, etc.
Gerald J.
07-15-2007 09:06:30
If the clutch plate is rusted to the flywheel, you might be able to get it in a high gear and break the clutch plate loose with the tractor brakes. Then you may be able to polish the clutch parts by slipping the clutch by holding the brakes with the tranmission in the top gear and slipping the clutch. If you get smoke from the clutch, you've polished too much.
Gerald J.
G/MAN
07-15-2007 12:03:25
 Re: 2510 clutch or gear problems? in reply to Gerald J., 07-15-2007 09:06:30
Once it's broken loose and working properly, it will clean itself up over time. Slipping the clutch intentionally is just asking for more problems.
