1971 4020
Marc Smothers
07-14-2007 19:24:26
Our new to us 4020 has started to start on its own. We put a new key switch on it and that did not cure the problem. With the key in run the signal wire to the solenoid has power. With the key off and we jump the solenoid it starts and is fine. When the tractor starts on its own the starter does not keep going as if the solenoid is locked.. We are completely new to John Deeres, everything else is Oliver/White (sorry). Would appreciate any ideas, Thank you, Marc
G/MAN
07-15-2007 08:43:29
 Re: 1971 4020 in reply to Marc Smothers, 07-14-2007 19:24:26
Which solenoid is getting power with the key in "run"? The actual starter solenoid mounted on the cranking motor, or the start relay? As far as that goes, neither should get power in the "run" position, and the cranking circuit should never get "start" power to the start relay or starter solenoid unless the key is turned to "start". Sounds like there's some wires crossed somewhere, bare wires rubbed to gether, wires connected to the wrong terminals, etc. You need a wiring diagram.
