'75 - 830 3 cyl. Wheel Question
Michael Sheik
07-14-2007 19:01:02
As you remember, bought this thing a week ago knowing I would have to do something with rear tire/wheel due to chloride leak. I am going to have to do something soon. Got a little weep around valve stem. After the tire shop removes water/tire/tube I am thinking I should sandblast the wheel and weld in patch around stem hole and apply rust-kill and paint. Am I on track or is there a better way to stop future rust. I'm open for an experienced recommendation.
Nylon
07-14-2007 19:55:50
 Re: '75 - 830 3 cyl. Wheel Question in reply to Michael Sheik, 07-14-2007 19:01:02
Most everyone here hates chloride. I actually like it. It is cheap and lays on way more weight than you can reasonably bolt on. I have a loader and that is pretty much the only reason why I like that weight. Otherwise I would go with bolt on. As long as the chloride is in the tube and stays in the tube there should be no problem. If you have the rim bare....sandblast it and paint it. May as well while it is off...you wont regret that. I have a 790 compact that deere says you can add weight to by just filling up the tubless tires. While I know that you can do it I never would. Some guys use sugarbeet juice. Depends what climate you are in too. Up here at -40 I can get chloride to go to slush. As far as the rim patch..depends on how bad it really is. If it is just surface rust, grind it smooth enough to have nice surface to tighten valve stem. My opinion anyway..
