2140 clutch problems
Wb.
07-14-2007 11:43:54
Bought a gooding looking one 5100 hrs.. Shifts fine when its' cold but have major problems to get out of gear when warm. It goes into gear fine.Free play is about 1 inch. If I stop engine it shifts O.K. Jacked one wheel off the ground it still turns with clutch depressed. Tried to slip clutch incase it has oil on it. Makes no diff. It doesn't act like a clutch problem. What else could it be? Tractor sat for couple years
HTR
07-14-2007 19:26:11
 Re: 2140 clutch problems in reply to Wb., 07-14-2007 11:43:54
Pilot bearing
buickanddeere
07-14-2007 18:51:51
Have you greased the clutch?
Wb.
07-15-2007 05:33:42
 Re: 2140 clutch problems in reply to buickanddeere, 07-14-2007 18:51:51
Thank-you for the replies. No I didn't grease the clutch. Can't get at it. I take it you think perhaps the clutch is hangin up. That what it feels like it. Good thought.
buickanddeere
07-15-2007 08:26:22
 Re: 2140 clutch problems in reply to Wb., 07-15-2007 05:33:42
The operator's manual has good pictures of how to get into the grease fitting on the throw out bearing.
