600-A Hi-Cycle questions
MasonX
07-13-2007 21:17:16
I help my uncle farm and he's still running a '72 600-A Hi-Cycle that's used on about 400 acres of corn and beans. It's been over WAY more than that in years past, particularly when the family did primarily cotton and some custom spraying on the side. It shared spraying at times with an IH 856, both of which have covered probably enough acres to make a person's head spin. God only knows how many hours the machine has.
All the equipment we use is all IH for the most part, but that sprayer just keeps on goin. The engine's probably had 2 or 3 overhauls over it's life. Lately we've had to do some work on it, as the pump directly above the alternator started slobbering fluid at the pully end of it. Deere no longer makes the pump, so a rebuild was done...which was apparently not done so well....still has fluid leaking some. I'd never fooled around it much til the past few days as I just mostly do tillage work and pull the grain cart at harvest. I got a few questions for any familiar with these older sprayers.
She's got a 3cylinder gasser, and I was wondering what other machines JD made that it was used in. I also was curious as to the difference between the 600-A and the regular 600, as well as the specs on the 700 and 737. Was a diesel engine available in any of these machines? I've seen a listing for a salvage 600-A w/ cab once, be nice to have one with AC but I'd imagine there's really no room to fit a compressor plus that 3cylinder has enough work pulling the machine with a full a tank.
We're the only ones I know of around running a hi-cycle this old. I'd imagine any others still working are relegated to spraying tobacco.
Mason
07-13-2007 21:33:11
 Re: 600-A Hi-Cycle questions in reply to MasonX, 07-13-2007 21:17:16
Ooops, I meant 734 instead of 737.
