My A ran fine one night, put some gas in the tank after i was done running it. The next morning i started it and prolly only went 100 yards and it shutdown, no bang/ strange noises, just like i had turned off the ignition (which i didnt do.) So I tried to fix it, but still to no use. it will just crank but it wont start. I am getting spark to only one of the plugs, but the other one isnt sparking. Last night i tried cranking it and oil shot out of a hole underneath the hood on the air cleaner, so... im not sure what thats about, but it is still doing it. And when it shoots out the oil it sounds like it is backfiring. I dont know if its just me but when it backfires the choke rod jumps back, so i dont know whats going on. I am about to start hunting around for a stick of dynamite. It is a 12 volt system with a delco distributor. Here is a list of the things i have done: Changed out the fuel, which was very bad (pretty sure it had H20 in it, along with some other crap... Checked the distributor parts, they all look o.k. Took off the carb and cleaned it put it back on. Got knew plugs. Charged the batteries twice now. Checked the ignition switch. cleaned the sediment bulb countless times. Made sure i had good fuel flow all the way through. And i am sure i am leaving out some stuff but heck if i no. That machine is really starting to bug me... haha... Just an assumption, But if i am getting spark down to the plugs isnt that all that counts? or am i wrong. I think since i am only getting spark to one of the plugs i am going to get new pulg wires, see what that does. Please guys you have helped me before with this tractor. i need your help once more.
