4010 with unusual sound in hydraulics
JWTexas
07-12-2007 21:49:54
My 4010 is now making what sounds like a "buzz saw" sound which comes and goes. I have noticed that the hydraulics takes a little time to work when first starting the tractor (PS and 3pt). The hydraulic/transmision fluid level is showing "safe" on the dipstick. The previous hydraulic problem was 4 years ago when the load valve for the 3pt was stuck and the sound was a high pitched squeel which was fairly constant when it began. This sound is a very different and will occationally occur for a few second at a time. Is this going to be the hydraulic pump going out and any idea on how much it would take to fix it?
Roy Suomi
07-13-2007 19:38:26
 Re: 4010 with unusual sound in hydraulics in reply to JWTexas, 07-12-2007 21:49:54
I'm not real familiar with ag tractors but , Does this tractor have a crankshaft driven hydraulic pump under the radiator?? Does the sound come and go with hydraulic function operation?? On industrial tractors and backhoes , it usually turns up to be a pump drive shaft problem..Loose splines or cushion bushings are shot..
Tx Jim
07-13-2007 04:12:24
 Re: 4010 with unusual sound in hydraulics in reply to Mike M, 07-12-2007 21:49:54
I'd suggest checkng stand-by pressure. Gauge should read steady at 2250 psi. Noise could be piston in pump or worn stroke control valve. Slow hyd. responce at start-up is due to hyd oil leaking back to sump which could be corrected by a check valve. Tx Jim
Gerald J.
07-13-2007 08:58:51
 Re: 4010 with unusual sound in hydraulics in reply to Tx Jim, 07-13-2007 04:12:24
There's a service information on the check valve. I have a version of it on my web page.
Gerald J.
