All I said is that to say that one must use a press would reduce damage is a guess, and that a lot of what he needs to do might be accomplished with a puller that he has handy, without everyone insisting that he needs to rent, buy, or borrow a hydraulic press that is a way more expensive way to go. It just seems so darn easy for people to recommend the best/most expensive tool for a simple job, when the appropriate application of a less sophisticated tool might do the job, albeit taking a little more time in set up and work. My point on your reverence to the FSB's, was that while you for one seem to always recommend an elegant and expensive approach, cloth yourself in the sanctity of the FSB's, was that, when it came down to installing pistons in your recent "H" block, you did not have access to a dial bore gauge, the method of measurement recommended in the Deere manuals, FSB's, and any basic motor building book, you chose the less elegant route of installing the pistons in a wobbly bore, and then wondering why they clunked. That's my point. While you seem inclined to recommend that folks go buy everything in the Snap-On catalog for a one-time "B" rebuild, when it came time, you did not. Not everyone has the tool pictured in the manual, or has ready access to it from a friend and sometimes you can achieve the same results with a file in lieu of having access to a milling machine. The point I have with a "a puller is press" is simple physics, and before everyone goes off telling me how a press is far superior, which for the given task, I will not try to deny, is wasted when you look at the photo in the 70 Diesel SM-2017 where the fellow is removing the large gear from the back of the pulley, arguably the toughest thing to remove on a Deere tractor, with a large puller. He is not using a press, and he is getting it done. The governor gears take no where that much force to unseat, so to HIS original question, to which I replied, that you could use a puller instead of a press, I replied that a effectively there was no difference. Do I think a puller will work? I don't know because I do not know how big a puller he has access to, and/or if he has access to a large press. Some of them are on there pretty good, and some are not. If he has too small a tool, the tool is at risk. If has too large a tool, the parts are at risk. As far as going off topic Pat, you did that. I did not stray from my original point, which was: If you have some tools, often used in combination, you can achieve the results of a press if you have a large puller and a vice. If the shaft is rusted, washing it in hot, soapy water, drying it thoroughly, and then running it through a cycle in a self-cleaning oven set on "clean" will often take it up to a temperature where the forged gears and the rolled shaft will break loose their crunchies to make removal in your press or puller of choice easier. Just be sure to remove the lead weights before cooking or you might find them in puddles in the bottom of the oven. I'm not arguing this anymore. I just hate seeing people directed to buy over kill, when they really need to be focus on measuring capabilities. Too many old machines get yanked apart and reassembled with nary a dial indicator or set of micrometers in sight.
