Rusted manifold bolt...now what?
Loren NC
07-12-2007 06:51:09
Removed three of four manifold studs. Fourth one won't budge. Soaked it with penetrating oil for days. Heated it red hot a couple of times. Put a long pipe wrench on it. It is rusted thin at the base, so I'm afraid to put too much pressure on it. Have tapped on the wrench with tension and on the end of the stud. Won't move. Haven't tried Coke yet. That's next. Any other ideas?
JMS/MN
07-12-2007 23:56:33
 Re: Rusted manifold bolt...now what? in reply to Loren NC, 07-12-2007 06:51:09
Heat the cast, not the bolt- more latent heat in the cast, the bolt just gets hot and melts away. Apply candle wax as it cools. Use a wrench on it or weld a nut to it. Never lost one yet. (If you're Catholic, use a blessed candle. If you're Protestant..... ....you're on your own, but good luck!!!)
Randy S
07-12-2007 20:49:10
Im a believer in Aerokroil as well...we use it at the job and its amazing. I would be careful about heating and cooling the cast. good luck
msb
07-12-2007 20:29:26
 Bees wax method in reply to Loren NC, 07-12-2007 06:51:09
Some people swear by the bees wax method. Heat the stud up cherry red and put the bees wax on the threads and melt it.Keeps the rust from locking the stud up by sealing the rust and acts as a lubricant. Can't say that I have ever tried it myself though.
Roy in georgia
07-12-2007 16:09:28
I love my impacts on old bolts because the amount of shock is on the bolt and usually will back bolts out even if rusted thin not on (hi setting)never hurt even a thin ear on exhaust manifold. So on the meaty block I would feel comfortable using it. If you have to drill it out make a simple jig with 2 pieces of metal clamp them together and drill 2 holes in them one for another bolt hole in the block the other for the one you need place a thick nut between the 2 pieces then line it up over your holes tighten it down in the good hole and then use gentle pressure and the other holes to drill it straight happy drilling Roy
Maark
07-12-2007 12:30:43
Cut the bolt off with about a 1/2" sticking up. Weld a washer to the remaining bolt then a nut to the washer. Let it cool a little or douse it with cold water and work the nut back and forth to loosen the threads.I've never had to drill out a bolt with this method.
Loren NC
07-12-2007 11:23:41
 What about this idea guys? in reply to Loren NC, 07-12-2007 06:51:09
Found this posted on the internet. Some guy took his job to a welding shop to have several studs removed. The shop guy used an arc welder. Clamped the hot side to the stud. Clamped the ground to the block. Set the welder at 150 amps and turned it on for 2 seconds. Studs got hot, head got warm. Crud was burned off. Studs came out without and difficulty. The shop guy claimed that 90% of all rusted studs could be removed with this method. Sounds simple. Any thoughts?
Loren NC
07-12-2007 14:08:00
 Upon more thinking....... in reply to Loren NC, 07-12-2007 11:23:41
Running current from positive weld cable through the stud would be exactly what happens if one used the approach of welding a nut onto the stud. Only difference would be that when you finished welding, you would have something to turn with. So how much does the current flow contribute to loosening the crud?
Loren NC
07-12-2007 10:50:00
Thanks for all the suggestions. I haven't tried the ice cube approach yet but have heated and cooled it a couple of times without any affect. I read somewhere that you can cool it with penetrating oil and it will penetrate more and faster. Didn't seem to work in this case. I like the sound of the welded nut and the use of an impact wrench. Since I have stud length to work with, I may try that if more heating and cooling doesn't work. I have never had much success with trying to drill them out. Must not be good enough with the drill. Never seem to end up with a hole exactly in the center as planned. If I end up breaking this one off, clearly drilling it out will be my last effort.
Mike Aylward
07-12-2007 09:40:52
Loren, many have given good suggestions. Here is what I do. I heat the the bolt first and let it cool naturally, going through the heat cycle that Frank mentioned. Then, I heat the area around the bolt AND the bolt and when both are hot I take an ice cube and cool JUST THE BOLT quickly. (Use gloves to avoid getting burned.) If there is anything at all to get ahold of after everything has cooled you usually can take a pair of vice grips and remove the bolt easily. In some instances you may have to repeat the process. Hope this may be of help. Mike
Easydoesit
07-12-2007 08:41:36
I have found that an impact wrench will remove rusty bolts much better than steady torque. If you weld a nut on the stud remaining and allow to cool and start at a low setting on the impact and then increase over time. I have also drilled and retapped many. Easy
F-I-T
07-12-2007 10:41:56
 Re: Rusted manifold bolt...now what? in reply to Easydoesit, 07-12-2007 08:41:36
Wow! If it's stuck enough to exceed the shank twist/shear load of a steel fastener in cast iron, you don't think you might just crack those threads or spin 'em out of that cast ledge? I think you need to be thinking about the amount of material the stud is engaged with, and consider the fact that it's cast iron....awfully brittle. If you wouldn't consider banging the block with a hammer for fear of cracking it, why would you pound it with am impact hammer? I'd rather cut them off and have a shank to heat and grab onto with a stud remover tool.
Interesting.....
Loren NC
07-12-2007 10:52:08
 Re: Rusted manifold bolt...now what? in reply to F-I-T, 07-12-2007 10:41:56
Now you are giving me second thoughts about the impact wrench approach! Your logic seems right to me.
F-I-T
07-13-2007 09:21:15
 Re: Rusted manifold bolt...now what? in reply to Loren NC, 07-12-2007 10:52:08
Loren:
That came from experience. You what experience is, don't you? It's what you needed to know right after it is too late.....
P Browning
07-12-2007 10:27:31
I sure can second that suggestion! I urge use of an impact wrench. If you are into these old machines without one, you are handicapped to begin with. (Pat)
Scotty H.
07-12-2007 08:11:53
I had the same issue on my 45 A. I got on E-bay and bought some rust buster called Aerokroil and soaked the stud for a couple of days. After using that stuff I'm a true believer. I'll never go back to WD-40. Aerokroil is made by Kano laboratories and on their web site they claim that Aerokroil will penetrate to 1 millionth inch spaces. If you go to their web site I think they have a money back guarantee if boughten through Kano labs. I might sound like an infomercial but I really do like that stuff.
Mike M
07-12-2007 08:04:57
It's alot less work to drill it and tap it out. Just keep the drill centered and don't go too deep as some models ( you didn't say what you have )go into the push rod tubes or coolant.
A milling machine is the best and then you can resurface it too. Which is a must on the dual induction ones like a 50,60,70 etc.
Scotty H.
07-12-2007 07:53:59
Probobly not what you want to hear but if you put the heat wrench to it and it still wont budge then I would grind it off flush with the head and then center drill, drill and tap the hole.
Loren NC
07-12-2007 06:52:45
Forgot to mention that the manifold is off. Stud is rusted into cast iron. Don't want to crack that.
F-I-T
07-12-2007 08:08:57
 Re: Rusted manifold bolt...now what? in reply to Loren NC, 07-12-2007 06:52:45
I had the same thing force me to replace a Cub block. Half the head bolts broken off flush, and were a real bear to get out, no meat in the web to helicoil, so once I checked the taper and wear in the bores, I just bought a re-bored block and moved on. You have more metal to work with here, so as was said, heat it up, let it cool, heat it up, let it cool. Several times will help to shock it as the steel and cast cool at slightly different rates. NOW, if you have to drill it out, heat it up, and bring the heat down very s-l-o-w-l-y, which should draw the hardness down from the 50's RC to maybe the high 30's RC where you can "machine" it with a drill. Once you get it drilled out close, heat it again, come down slow, and the remaining threads should peel out of the stud hole. Then take an awl and pick them clean. Be careful using the tap in there so you don't oversize the threads. You'll have to sue some sealer on those bolts/studs, whichever you choose to use, so coolant doesn't weep up the shank.
Frank
