360 Gas Engine out of 4020 console
Delmar
07-11-2007 10:37:05
Did the 7700 combines use the same gas engine as a console 4020? What gas engine did the 105 combines use? Thanks in advance
Bob
07-11-2007 21:14:34
 Re: 360 Gas Engine out of 4020 console in reply to Delmar, 07-11-2007 10:37:05
The combine gas engines, at least off of the 105's, had 5 main bearings, while the tractor engines had 7 main bearings.
95EB
07-12-2007 08:07:16
 Re: 360 Gas Engine out of 4020 console in reply to Bob, 07-11-2007 21:14:34
Regardless of the machine they were put in, the 362 gasoline engines had five main bearings.
JDmninSD
07-16-2007 18:46:20
 Re: 360 Gas Engine out of 4020 console in reply to 95EB, 07-12-2007 08:07:16
95EB i think you better check your math 6 cyl engines have 4 mains on gas and 7 on diesels
Gerald J.
07-11-2007 19:26:16
Close, probably called a 361 power unit. My early gas 4020 with 340 is close to a 341 power unit used on a similar vintage combine. But there are almost NO part numbers in common between the 340 gas 4020 engine and the 341 power unit. Oil filters are a great deal different.
Gerald J.
poppa
07-11-2007 12:09:10
i am not sure about the combines, if you
need a motor, i saw a gas motor on the classifieds.
