JD 1010 Carb
fireman
07-11-2007 09:15:45
Getting ready to order a kit for my carb and I was wondering how many different kinds of Marvel- Schebler carb's are put on these tractors. A friend told me i can get it from NAPA but they need the number off the carb and I cant find it. I see ebay has some online but don't know if my carb will work with their kit. 1963 RU. Thanks!
Bob
07-11-2007 21:21:45
 Re: JD 1010 Carb in reply to fireman, 07-11-2007 09:15:45
I was going to suggest simply getting one from DEERE, part # RE526718, but at over $78.00, maybe NOT!
fireman
07-11-2007 16:55:32
Thanks guys. I have found out that mine is A TSX-860. The plate was buried under some grease. I had also heard of TSC for the kit but not any close buy. NAPA will work I can wait a few days. Thanks Again!
Roy in georgia
07-11-2007 18:25:07
 Re: JD 1010 Carb in reply to fireman, 07-11-2007 16:55:32
if you want to see what they have or order from them they will send you a catalog they have or can get alot of stuff. Some people think they are just alot of trouble to buy from or cant get what you need but I think its only the ones that are used to going to the dealer for parts here you have to do some of the catalog work but the saving is worth it and good stuff.
Roy in georgia
07-11-2007 16:02:26
look up tractor supply co. I was in the Griffin Ga. store and they have some kits in stock maybe for yours if you are close to one.I used one of their kits on my cousins super c and used the it manual to make other adjustments this thing will start with the hand crank even after setting over a month usually in 4-5 cranks setting 1st crank if it ran that day
Osage
07-11-2007 12:58:58
Fireman:
According to my "rinky-dink" I T manual they only put one kind of M-S carb on the 1010's, which was a (TSX-809).
For what its worth, that appears to be the model of M-S carb that is on my, 1965 1010RU.
Osage
